Business Broadband Voice and Asterisk
osxkris
Member
Hi there,
We currently have our BT land lines and one other (non-BT) VOIP line feeding into an Asterisk server in our office, but we have one other line that we use, our BT Business Broadband Voice line, with a geographic number.
I have attempted to set-up this VOIP line with Asterisk, but have had no luck. Has anoyone else successfully achieved this?
The required details are:
username - I have tried our 05... number with and without international prefix
authuser - I have tried 05-number@bmnhb-02.bt.com
secret - Tried the password that is passed via HTTP GET when setting up the line on the router
host - Tried bmnhb-02.bt.com
outboundproxy - Tried bbvservice-560311.bt.com
The domains, usernames and passwords above I stripped out of the HTTP GET request when setting up the line with the BT router, but can't get them to work. Am I missing something?
Many thanks.
2 REPLIES 2
Fiona
Grand Guru
Hi
To do this you would need to VoIP credentials, which is not something our Broadband Voice team would be able to supply.
I'm sorry about the delay in responding Osxkris.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
nick_wong
Member
Hello osxkris,
Did you manage to set up Business Broadband Voice and Asterisk?
Whether or not you did, I would greatly appreciate it if you could share any fruits of your research.
BT are now offering a package with inclusive calls to UK mobiles, which would be a big saver for us
if we could set up a trunk on our Asterisk server for outgoing calls to UK mobiles.
If the Falcon IP phone uses a standard, unencrypted protocol eg. SIP, it would be possible to obtain the login details by monitoring the network traffic to/from the Falcon Phone with a tool like tcpdump (Linux/Unix) or Ethereal (Windows).
Thanks in advance
Nick
