I needed to access my site to do amenments from Cyprus on Business matters, as bt has said for my own
security ??? you have to email or phone Now back in the UK I have a question how can get over this issue as I do spend a lot of time in Cyprus.
Regards
Pete
Solved! Go to Solution.
Hi Pete,
When you are outdside of the UK, you can still edit your website by going to https://hosting.hostingbt.com/OS4/index.php once you go here you will need to login with your FTP username and password.
Reagrds
markp
Hi Pete,
Reagrds
markp
Ok Mark
Thanks Shall give a go next time out.
Pete
Hi Markp
I have just put the link into the browser https://hosting.hostingbt.com/OS4/index.php, but came back with 404
is that for outside the UK
Pete
Hi Pete,
Its should work from within the UK too, try going to https://hosting.hostingbt.com/OS4 . You should get a login screen
Hi Mark
That seems to work will give a try in Cyprus.
Thanks for your help.
Regards
Pete
