I know its the standard upload speed but I was wondering if I can have my upload speed uncapped as it sits at
448 Kbps
My stats are:
| Downstream | 8,128 Kbps |
| Upstream | 448 Kbps |
ADSL settings
| VPI/VCI | 0/38 |
| Type | PPPoA |
| Modulation | ITU-T G.992.1 |
| Latency type | Fast |
| Noise margin (Down/Up) | 9.2 dB / 25.0 dB |
| Line attenuation (Down/Up) | 28.0 dB / 18.0 dB |
Solved! Go to Solution.
Hi lissitt
Unfortunately this is not something we can do on a 8Mb max service. When your telephone exchange upgrades to ADSL2 or the Fibre products, then you will see an increase in your upload speeds.
Regards,
Brian
Hi lissitt
Regards,
Brian
