DNS Problem
Pontresourcing
Member
Hi,
I'd like someone to double check if the new dns settings for my domain name pontresourcing.co.uk are correct - I'm hosting the website on another server.
The control panel has very limited functionality and some options to change in dns records are disabled.
The settings I need are:
                         79.170.44.156
*                       79.170.44.156
ftp                     79.170.44.36
mail                    79.170.44.56
ns1                    79.170.40.2
ns2                    79.170.43.3
www                 79.170.44.156
I hope it won't take you long.
By the way why don't you have a live chat here, as all the serious hosting providers?
Thanks in advance!
11 REPLIES 11
Ian1974
Moderator
Moderator
Hi Pontresourcing,
If you wish to update the nameservers, please use the namserver re-point form at www.dnsforms.co.uk.
Please note that although we can update the domain records prior to changing nameserver, once the nameservers are changed the setting will be lost.
It is best to contact your new hosts and ask them to set up your current dns settings then submit the nameserver re-point form.
Kind Regards,
Ian - F -
RobertPattinson
Member
hi,
I'm hosting the website on another server.[
thanks
Samsung Galaxy S2 cases
