Domain config ? ftp access to .co.uk
classroompixie
Member
I have a .com and .co.uk domain name. (http://www.classroompixie.com & http://www.classroompixie.co.uk)
All is well with the .com domain! Hurray!
However when I ftp to the .co.uk domain I am connected to the .com one.
I want to do a 301 redirect via htaccess file to my .com site, just need the ftp access to be able to park the file in the right place.
In the maintenance section of the BT configuration for my sites I see that the ftp IP address for both domains is the same, could this be the problem I ask myself?
Two things; firstly the ftp entry is greyed out and cannot be changed, at the access level I have, secondly even if I could change it what should it be changed to.
Thanks!
14 REPLIES 14
alastair
Grand Guru
you need to have a hosting pack for each domain to seperate them... or...
do some form of web splitting that is technically possible but its a tad sloppy
=~~= All Glory to the Hypnotoad! =~~=
classroompixie
Member
I have the advanced/professional package as well as the business package.
Should give me the what I need, if I have understood it correctly.
Both domains say I have hosting on them in the configuration manager.
Is it normal for the ftp IP address to be the same on 2 different domains?
I have a feeling that the .co.uk was just never set up properly by BT.
alastair
Grand Guru
yes it can use the same ip as BT host alot of webspaces on that ip.
you will have to check you activate/registered the domains to the seperate packs.
it may be you didnt activate the .co.uk yet so it defaults to being directed at the .com
classroompixie
Member
Says registration is complete on both in the configuration manager.
Says I have hosting on both too.
Previously the .co.uk was set to forward to .com in the domain manager configuration, which worked fine, took that off a while ago.
I did not like the 302 redirect that was used for this and wanted to upload a 301 redirect in .htaccess file.
The .co.uk url just 401s now.
 Bound to be something simple (probably me thats simple). Thanks for the input.
If someone from BT could look at this it would be helpfull, as you will be able to see whats what from the servers perspective.
Many thanks.
alastair
Grand Guru
kl fair enough. thats me out of ideas. not too au fais with BTs webhosting and how exactly it works
classroompixie
Member
np thanks for having a think about it. Smiley Happy
Bound to be either a simple configuration error or a simple configuree error (namely me).
Love a BT view on it.
classroompixie
Member
I have 2 domain names registered through BT, .com & .co.uk, I would like to redirect the .co.uk to the .com.
The standard method of redirecting provided through the BT domain center manager uses a temporary (302) redirect.
This works fine!
I would really prefer to use a permenant (301) redirect as this is viewed in a better light by search engine spiders.
I would expect to have to edit the .htaccess file on my.co.uk domain to accomplish this, no problem there.
Except that when I ftp onto the .co.uk site it connects me to the .com site, leaving me unable to redirect my .co.uk url in the way I would like.
It would be handy to be able to choose the type of redirect offered by the domain center manager perhaps BT may be able to look into providing this functionality in the future.
In the mean time anyone know how I may be able to get the redirect I would like?
Alun
Master User
Hi classroompixie,
I would suggest to contact the Domain & hosting support regarding this to look into your issue.
Regards,
Alun
BT Business Support Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
classroompixie
Member
Alun thanks for tying up my two posts.
I contacted them yesterday no reply as yet even though the stated response time was 1hour 30 mins.
Perhaps its a tricker problem than I think.
Busy weekend ahead I will persue them next week.
