I am trying to produce my first website using the "Easysite Wizard" (which is not easy!)
I am trying to add three categories to my Products. I have down this via the "menu editor" and then used the add buttons to add my 3 pages/boxes.
When I add text/photo to one of the pages, it appears on all of the 3 pages
How can I stop this? I have been trying for 3 days........................Can some please help?
The simple quick user guide is not that friendly
Solved! Go to Solution.
I was curious as to why people are using easy site wizard 6 ... as BT advised me to use easy site wizard pro ... I am jsut starting and experimenting/learning.
I have to say that I was not too impressed with the quick tutorial which shows how you can create a web site in a flash ... makes it look easy, too easy.
After watching it I went straight to try build my own site and get into big mess.
Then I downloaded the EasySiteWizard 7.5 Professional user guide (some have posted links this). I worked all the way through it, did not take to long and a learned a lot ... in particular I am now impressed by how wonderful and flexible and powerful ESW Pro is ... at least to an amateur like me.
Hi Wayne,
This is the first time I have ever been on a blog!!
I am new to "EasySite Wizard" too and am still struggling to get it to do anywhere near what I want.
As no one has posted you a response yet, I thought I might pluck up courage to suggest that perhaps you are in "Master Page" and that is why it's appearing on all pages????
Sorry if that is totally wrong and unhelpful.
In the meantime, talking of Master Page - do you know how to get back into the Master Page - I've been tearing my hair out! The EasySiteWizard 6 User Guide doesn't seem to mention it, but then it does mention a whole load of things, like the "Insert" and "File" Menus, and "SiteSpark" all of which I don't seem to appear on my screen.....
Also, any idea of how to get colour into the white spaces where my background photo doesn't cover?
Good luck with your website and I hope someone comes up with an answer for you soon.
BirdBrayn
Hi Wayne
What is your domain name?
