Does anyone know a way I can add the feedback table/s from my ebay shop to my BT Shop? Is there an app or badge out there i can add or do I have to do it with a hyperlink.
I want it so that I can build trust in my website, as i have over 4k feedback 100% positive, so would prefer if I could get the feedback table as an element rather than encourage somebody to buy through my ebay shop (which then incurs ebay fees).
First result:
http://widgets.yahoo.com/widgets/ebay-feedback-watcher
Have Fun 😉
EDIT: Sorry that was an offline Widget - the solution to put it on your website is even more simple:
<script type="text/javascript" src="http://ebayfeedback.easystorehosting.com/esh/ebayfeedback/feedback.php?eBayId=eBay-User-Id"></script>
Just put this in an user defined page element, replace "eBay-User-Id" with your actual ebay ID, and you're done...
Cheers!
