Email not forwarding to alias
UK_Al
Member
I have set up an alias "[email protected]" for the website I am hosting through my primary domain, but test messages are not being forwarded from the alias address to my primary email account "[email protected]". I have checked the spelling several times, and sent test messages through a couple of different accounts. My primary email account is working.
I am wondering if this has something to do with zone configuration. BT allowed access to domain forwarding yesterday (Thanks Dave for your advice), but is there anything else I'm supposed to do?
cheers
Al
1 ACCEPTED SOLUTION
Accepted Solutions
Fiona
Grand Guru
Hi
I have spoken to the technical desk in regards to this issue. They were not able to test the account as you are forwarding emails away from BT. They have suggested contacting the technical helpdesk if you want this looked into so they can stop the forward and fully test the account.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
View solution in original post
3 REPLIES 3
Fiona
Grand Guru
Hi
Have you managed to get this fixed?
Kind Regards
Fiona
UK_Al
Member
No, I set up a primary account for the sisterkenny website, so I didn't pursue the issue.
Allan
Fiona
Grand Guru
Hi
Kind Regards
Fiona
