Frame Forwarding fails
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi there,
I have a problem, and i dont understand why it even is there.
I have created a homepage for the site: http://www.steelandjelly.co.uk and while publishing it, a messages tells me its to be found under http://steelandjelly.co.uk.c31.sitepreviewer.com ? So i go into domain forwarding, and want to forward the frame from http://steelandjelly.co.uk.c31.sitepreviewer.com to http://www.steelandjelly.co.uk, but this is not possible because of some record?
Please help.
/Ann
0
Kudos
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You are seeing that message because your website is not pointing to the IP address associated with your hosting. The link that it is giving you is usually used to preview a site before repointing the domain to our IP's. If everything is acceptable on that link I would suggest contacting your current registrar, or whoever controls the nameservers you are pointing to currently, and ask them to point your site to 209.235.144.9. Hope this helps.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks for you reply . the hosting is done by bt would you know what number to ring or dept to contact ?
thanks
ANN
0
Kudos
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Fill in the form avalable on this link and someone should be able to sort it for you farily easily.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I would say check out http://btbusiness.custhelp.com/app/home under the DNS section, there should be either a chat option or a phone number to call there.
