Help Interleaving
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi ok,
For the past 10 years with several providers i have acheived between 10-15ms with Fast path, I started my service on the 3rd Febuary and was acheiving 12ms last hop to bbc.co.uk. A trace from my previous provider,
1 <1 ms <1 ms <1 ms 192.168.0.1
2 10 ms 10 ms 10 ms 188.39.0.30
3 9 ms 10 ms 10 ms gi1-8.the.dist.dsl.enta.net [188.39.0.29]
4 10 ms 10 ms 10 ms te2-2.telehouse-east3.dsl.enta.net [78.33.141.81
5 24 ms 10 ms 10 ms te5-2.telehouse-east.core.enta.net [62.249.192.1
21]
6 10 ms 10 ms 10 ms te5-1.telehouse-east2.core.enta.net [87.127.236.
98]
7 9 ms 10 ms 10 ms 212.58.238.177
8 10 ms 10 ms 9 ms 212.58.238.153
9 10 ms 10 ms 10 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
A few days later the interleaving got kicked on and i was told to wait 10 days for the training period to stop to remove it, So i waited and on the 14th i then asked for it to be removed... And eventually they told me they sent an order to get it removed.
48 hours later i am still seeing the increased ping from the interleaving and have been told it has been removed from my line, Below are stats showing that interleaving is still on.
Status: ShowtimeRetrain Reason: 8000
Channel: INTR, Upstream rate = 960 Kbps, Downstream rate = 7296 Kbps
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.6 7.0
Attn(dB): 43.0 26.5
Pwr(dBm): 19.8 12.7
Max(Kbps): 7872 1136
Rate (Kbps): 7296 960
G.dmt framing
K: 229(0) 31
R: 16 8
S: 1 4
😧 32 4
ADSL2 framing
MSGc: 59 10
B: 120 46
M: 1 4
T: 2 3
R: 10 4
S: 0.4962 5.9076
L: 2112 260
😧 64 4
Counters
SF: 4837 4777
SFErr: 0 0
RS: 328946 81209
RSCorr: 80 0
RSUnCorr: 0 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1415545 0
Data Cells: 542 0
Drop Cells: 0
Bit Errors: 0 0
ES: 3 0
SES: 0 0
UAS: 96 0
AS: 83
INP: 1.21 0.24
PER: 16.12 17.72
delay: 7.93 5.90
OR: 32.24 7.22
Bitswap: 0 0
Strange enough i thought id try adsl2+ mode out to test so i did...
Channel: FAST, Upstream rate = 1011 Kbps, Downstream rate = 7770 Kbps
Mode: ADSL2+
Channel: Fast
Trellis: U:ON /D:ON
I am currently connected with adsl2+ and i am seeing,
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
2 19 ms 19 ms 19 ms 217.32.141.34
3 21 ms 21 ms 22 ms 217.32.141.62
4 22 ms 22 ms 21 ms 213.120.161.50
5 22 ms 22 ms 22 ms 217.41.222.50
6 22 ms 21 ms 22 ms 217.41.222.182
7 22 ms 22 ms 21 ms acc2-10GigE-0-0-0-4.bm.21cn-ipp.bt.net [109.159.
248.194]
8 28 ms 28 ms 27 ms core1-te-0-2-5-0.ilford.ukcore.bt.net [109.159.2
48.128]
9 27 ms 27 ms 27 ms core1-pos9-1.telehouse.ukcore.bt.net [194.74.65.
114]
10 228 ms 223 ms 219 ms 194.74.65.42
11 27 ms 28 ms 27 ms 212.58.238.153
12 28 ms 27 ms 27 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
The trace from g.dmt currently shows,
2 13 ms 13 ms 12 ms 217.32.141.34
3 14 ms 13 ms 14 ms 217.32.141.62
4 15 ms 15 ms 15 ms 213.120.161.50
5 15 ms 15 ms 15 ms 217.41.222.46
6 16 ms 15 ms 15 ms 217.41.222.182
7 16 ms 15 ms 16 ms acc2-10GigE-0-7-0-4.bm.21cn-ipp.bt.net [109.159.
248.198]
8 21 ms 20 ms 20 ms core1-te-0-13-0-4.ilford.ukcore.bt.net [109.159.
248.136]
9 21 ms 21 ms 20 ms core1-pos9-0.telehouse.ukcore.bt.net [62.6.201.1
18]
10 21 ms 21 ms 21 ms 194.74.65.42
11 20 ms 21 ms 21 ms 212.58.238.129
12 20 ms 20 ms 20 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
When i first started the service these pings were -10ms as what they are now, Im running around in circles what am i supposed to do, My end still showing interleaving but they say its off and are now blaming me?
More stats from the modem,
System Status System Uptime: 23:5:24
Primary Secondary
LAN Status Primary DNS: 195.74.113.58 Secondary DNS: 195.74.113.62
IP Address TX Packets RX Packets
192.168.2.1 1138827 1145082
WAN 1 Status
Enable Line Name Mode Up Time
Yes SDSLADSLEthernet PPPoA 00:00:00
IP GW IP TX Packets TX Rate(Bps) RX Packets RX Rate(Bps)
--- --- 0 0 0 0
Message [ PPP Shutdown ]
WAN 2 Status
Yes Ethernet --- 00:00:00
--- --- 0 0 0 0
SDSLADSL Information ( SDSLADSL Firmware Version: 332201_A)
ATM Statistics TX Cells RX Cells TX CRC errs RX CRC errs
246594 33206010 203 150
SDSLADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
G.DMT SHOWTIME 1152000 6912000 6 42
Am i right in thinking if it was off then i wont see the errors above? Since interleaving is error correcting and if it was indeed off then these would show as 0 as they did with my last provider...
System Status System Uptime: 498:11:2
Primary Secondary
LAN Status Primary DNS: 194.74.65.69 Secondary DNS: 74.82.42.42
192.168.2.1 16478663 11423677
WAN 1 Status
--- --- 0 0 0 0
WAN 2 Status
--- --- 0 0 0 0
9521188 301313422 0 0
G.DMT SHOWTIME 896000 6304000 8 44
Sorry for the long post but im getting really frustrated trying to resolve this and im not getting anywhere, I appreciate your replies and any advice given.
Regards
Darryl Williams
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Another freshly done trace currently on g.dmt
2 16 ms 16 ms 16 ms 217.32.141.34
3 18 ms 17 ms 17 ms 217.32.141.78
4 20 ms 19 ms 18 ms 213.120.161.50
5 22 ms 19 ms 19 ms 217.41.222.58
6 19 ms 19 ms 19 ms 217.41.222.182
7 19 ms 19 ms 19 ms acc2-10GigE-0-5-0-6.bm.21cn-ipp.bt.net [109.159.
248.228]
8 24 ms 23 ms 24 ms 109.159.248.132
9 24 ms 25 ms 24 ms core1-pos9-0.telehouse.ukcore.bt.net [62.6.201.1
18]
10 26 ms 24 ms 24 ms 194.74.65.42
11 25 ms 25 ms 24 ms 212.58.238.153
12 25 ms 25 ms 25 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
So sometimes it ends in 20s like my previous post and sometimes 25's
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Barryl87, interleaving is either on or off and is used to help with the stabilisation and noise reduction of DSL connection on longer lines. This is turned on as default on almost all connections to broadband in the uk.
I can see no problem with the ping times you posted as the time is actually very good. Your connection stats are very good and sync rate is also very good. You have some errors in the logs but not too many.
I am a little confused as to what is actually the problem? can you please explain?
Regards
Mal
These Forums are for BT Business customers to discuss how to get the most out of their BT Business products and services with other customers. If you have an issue that needs to be resolved by BT please contact us. Off topic posts will be removed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just to be clear i started the service on the 3rd and interleaving was off and the ping times were 10ms-12ms a few days later the interleaving kicked in so i jumped to 25ms, I then asked for it to be removed and am getting told that it is indeed off but im still seeing the same 25ms ping that i did when it came on.
It is still showing as on from my end but they say its off and are now blaming my end... What am i supposed to do?
Cheers
Darryl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Barryl87, do you use your broadband for online gaming?
Your post shows that Interleaving is indeed still on for your ADSL. If a request was sent to BTWS to have it switched off then that is what should have happened. A note to make though is that interleaving when on is controlled by DLM which is a software algorithm that continually monitors the line for any errors. DLM will determine whether interleaving and error correction should be on or off and in most cases should be left to do its work without interference. DLM Automatically adjusts line parameters to maintain stability.
Effectively if you turn off interleaving then you may experience reduced stability on your connection. However as I said before if you requested it to be turned off then that is what should happen. But, you should understand what may happen if you do turn it off.
The only thing you can do is contact us and re request that interleaving be turned off.
Before you do, a word regarding your connection! have you connected your filter to the BT Test socket? Read this Article
After reading that article and you have tested from the main bt test socket you still feel that interleaving should be switched off then use the contact us link above.
Regards
Mal
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Finally someone with a bit of sense all i got from the live support was its off and it must be my end... My recent errors from the modem are very low now i had only 18 RX CRC errors in 38 hours my line is good and ive always had it off without trouble, Thanks for confirming that it was on ill contact you later.
Cheers
Darryl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Had a word with live support again and they are now confirming from BT Wholesale that its also off from their end, So what am i supposed to do its clearly not off and i cant do anything about it.
Is it possible to move from the business broadband to the home side of it and hopefully ill get more luck there? Another up to date trace to confirm,
2 21 ms 20 ms 21 ms 217.32.141.34
3 22 ms 21 ms 21 ms 217.32.141.62
4 23 ms 24 ms 23 ms 213.120.161.50
5 24 ms 23 ms 23 ms 217.41.222.62
6 24 ms 23 ms 24 ms 217.41.222.182
7 24 ms 23 ms 23 ms acc2-10GigE-0-7-0-4.bm.21cn-ipp.bt.net [109.159.
248.198]
8 29 ms 29 ms 29 ms core1-te-0-13-0-4.ilford.ukcore.bt.net [109.159.
248.136]
9 29 ms 28 ms 28 ms core1-pos9-1.telehouse.ukcore.bt.net [194.74.65.
114]
10 161 ms 218 ms 217 ms 194.74.65.42
11 29 ms 29 ms 31 ms 212.58.238.129
12 29 ms 29 ms 29 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Darryl,
I've had this escalated for you to see about getting interleaving turned off, it's possible this won't be done till monday afternoon though I'm afraid.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So can you actually see its on? If so why do the people at live support keep saying that its off?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Any news on this?
Cheers
Darryl
