Hit Counter
tweeker
Member
Can anybody tell me how to add a hit counter using EasySite Pro?
1 ACCEPTED SOLUTION
Accepted Solutions
JohnE
Guru
I am sorry for this, Tweeker.  The cut-down version of EasysiteWizard Pro was made available as a "courtesy" to all our customers, albeit in a cut-down manner.  Obviously, you would need to upgrade in order to have access to all of the features.
There is no reason why you can't use a "3rd" party script, you can insert page code in EasySiteWizard pro.  There are many easily available scripts, some very easy to use and some more advanced.
View solution in original post
17 REPLIES 17
markp
Grand Guru
Hi Tweeker,
if you go to  Where can I find the EasySiteWizard Pro user guide? this takes you to the page to download the user guide for easy site wizard.
Something else you can look at is the statistics in the website center through our website. Once in the website center click on statistics then click on web stats, then create a report, then show report. And this link explains how to read this report.  Webalyzer explanation: How To use Webalyzer
Hope this is of help.
JohnE
Guru
Thanks for that, markp, I belive that the section in the user guide is:
8.16 Adding a widget to your page
Also, thanks for the link about Webalyzer.  It's worth knowing that support provided by the Helpdesk is confined to simply making sure it works.
tweeker
Member
Thanks for trying to help.
In EasySite Wizzard Pro under the Wiedget tab I only have two items listed, Google Map and Bt Trader.
As to the User Guide, it does go anywhere near explaining anything beyond the very basic and it certainly does mention anything about Hit Counters.
JohnE
Guru
Tweeker, please see this thread:
Web Counters
It may help.  Easy Site Wizard does allow you to insert your own code.  We provide two scripts for this, in the Plug In Scripts section of Site Buiilders.  Using these will provide some code for you to insert into your website.
tweeker
Member
Thank You JohnE,
I see why that might help me, but on my screen under the Site Builders tab I only have 3 items:
Easy Site Wizzard, Easy Site Wizzard Pro and Photo Album. I cannot find Plugins anywhere.
JohnE
Guru
Tweeker, in Easysitewiz Pro, can you click the third icon from the right in the toolbox?  This should show a dropdown menu with Visitor Counter as a selection.
tweeker
Member
JohnE,
Thanks for staying with me on this issue.
I cannot see a toolbox icon.
The 3rd from the right icon has ABC with a tick mark on it. This is only available whe I'm editing a text field.
2nd from the right I have an icon with a hammer on it. This normally means a toolbox but when I hover over this icon it shows "Create Web Form". When I click on this it goes into the webform creation procedure. This button does not have a dropdown list.
JohnE
Guru
There is an Icon on your toolbar with a Star on it, that's the one you want.
tweeker
Member
Hi JohnE,
That one only lists 2 items, Google Map and BT Trader. Its in one of my earlier messages.
