If you use Content Screening please read this.
DaveA
BT Partner
BT Partner
Hi all,
As part of the question about Content Screening I need to find out the make and model of the router you're using it on.
If you could also include the firmware version, which you can find on the router summary page, then that would be great.
Thanks in advance.
Dave
26 REPLIES 26
bombinho
Super User
@whiller123:
nope everything is working fine at the moment. I just wondered about the fact that obviously firmware changes are getting carried out without reflections in the firmware version.
For the first days the content screening could not even be felt. Normally its around one to two seconds for a not recently used server. Not so during that time. Almost instant response. But now everything goes back to normal.
whiller123
Super User
@bombinho
"Happy days"
Rob
whiller123
Super User
@DaveA
Dave some time ago you said "the question has been asked" obviously RE: content screening.
Has the question been answered yet?
There are a few of us wanting to know
Rob
whiller123
Super User
@bombinho
You obviously use content screening just like I do, have you noticed an increase in port scans & attacks since you are using the screening again?
I have switched a customer back from Open DNS to Bt yesterday and within half an hour port scans & attacks.
Even when I refresh the IP address the same attackers are back within minutes. I switched back to open DNS overnight and the attacks stopped, well apart from the usual random attempts. I have spent this morning switching back to Bt & guess what? the same attackers from China are back within the hour. I refresh the IP and within minutes they are back again, this is to much of a coincidence. I will start switching the rest of my clients back tomorrow to attempt to prove the point.
If you get a minute could you look at your log & let me know if you have the same issue.
Rob
bombinho
Super User
@whiller123: No can not confirm that from here. Nothing in the attack alerts since 3 days. I had to reboot the router as it had become unresponsive. Not a single entry since then. Port scans are very rare anyway nowadays. Usually syn floods or other subtle forms of communication attempts. An incredible amount of communication attempts targets the NAS directly and goes through the hub like a hot knife through butter. Just the NAS is not connected. That follows me around at the moment.
Engineer
Member
whiller123
I am having a lot of pokes at my open ports too 9090,5900,1723
Even when I re-boot the Hub they seem to find me again & I do not have a static IP
Always seems to be from the same Chinese & US IP addresses this one is the most persistent 50.166.6.70
I will turn off the content screening re-boot & report back
Engineer
Member
whiller123
Hi Rob
Well i'll be damned, well spotted, you are right I have played with this all afternoon & yes you are spot on.
I have a small network if I put the screening back on but do not use a device nothing, minutes after a DNS request is processed. it kicks off again I believe this content screening is compromised.
Not sure what to do now back to open DNS I am thinking.
Thanks for that
Everyone else beware
whiller123
Super User
@engineer
Hi yes I had suspected this before but was not sure, I noticed that the "poke's" as you put it at my open ports all but stopped on 1st August.
Looking at the ports you have listed in your post you can change the VNC & AversMedia port range to something less obvious
When you connect with VNC it is just the IP address or domain then ::port number  IE:        you.dyndns.org::5908
with Avers it is in the remote software. don't think you can change your PPTP but passwords need to be the best they can be
Don't mean to teach you to suck eggs but hope this helps
Rob
Engineer
Member
Whiller123
I understood the VNC & Avers comments I guess the other was referring to my Windows VPN
I have decided to leave the ports as standard & as my OpenDNS is still active I have switched back to that.
I have never had issue with OpenDNS & I am not convinced that the BT screening is fully sorted.
Thanks for your suggestions though
Engineer
Member
 This version now has content screening
Model:2701HGV-C
Hardware Version:2701-100630-008
Firmware Version:6.3.9.41-plus.tm
