Wireless Problems with Vista and Business Hub-2701
JohnE
Guru
I have been made aware by a colleague on the Ethernet support team of an issue with some users having difficulty establishing wireless access when using a Windows Vista computer, the new Business Hub-2701 and WPA/WPA-2 security.
You will need to update the wireless adapter driver.   In some cases Vista will show the drivers for the wireless adaptor in the optional updates section.  Also it will not find the drivers when you try and automatically update Atheros wireless adaptor.  In this situation you will need to update the driver manually.
Foxconn Wireless AR5007EG Lan Driver (Atheros AR5007EG)
If you are affected by this, can't find the correct driver and get it installed, please Contact Us
0 REPLIES 0
