Won't let me change network
droslisluk
Member
Hi all,
I have been using the wireless network for ages, and I have just tried to add a new machine via the wireless network connection.
It has automatically connected Pozycjonowanie stron to BTOpenzone and will not let me disconnect from it, and won't search for other networks. So I am stuck on the openzone and not on my business hub?!??!?! What can I do?
Please help, I am going out of my mind and am ready to start smashing the bloomin thing up!!!
2 REPLIES 2
MHC
Guru
Use the wirelss manager on your PC to disconnet and make Openzone a manual connect.   Then search for other SSIDs and create a profile for your hub.
If you cannot force a disconnect from your PC, then it is your PC software at fault and NOT the hub.
mithcd
Power User
If you are using WIndows 7, you can remove BTOpenzone under manage wireless networks. That is also another trick.
