have not received an email since Saturday 25 may everytime i switch on panel comes on screen and asks me to login
everytime I put in details panel reappears I can no longer send emails I have recently changed password so I know I am entering correctly
Solved! Go to Solution.
Hi Frogman i am sorry about that, can you make sure you are suign the correct server settings
those will be
Incoming server
Server - pop.outlook.com
port – 995
connection type – ssl
ensure that this is authorised with the full email address and password including the domain [email protected]
Outgoing
Server - smtp.outlook.com
port – 587
connection type – tls
make sure the outgoing server requires authentication and authenticate with the same details as the incoming server
those will be
Incoming server
port – 995
Outgoing
port – 587
thanks for reply bug in my system all working ok now thanks again
Your very welcome, thanks for letting us know this has been solved
I have a Nexus 7 and can't set it up to send email, I can recieve but when i configure the outgoing setting it doesn't allow me to use the 587 Port. I get the option to select SSL/TLS or SSL/TLS (accept all certificates) but both of them suggest port 465. If I select that port I get the message
'Couldn't open connection to server'
and I change the port to 587 I get
Can't safely connect to server
(javax.net.ssl.ProtocolException:SSL handshake aborted:ssl=0x etc......
Can you advise how to fix,
Hi
Having waited 3 weeks to be connected to broadband, tv & phone I a less than impressed to find that our hotmail account doesn't let me send messages which is not helpful given we run a business using this address.
Can anyone make a recommendation as to how we can fix this? I see that it has been an ongoing issue.
