domain without www.
evilpop
Member
hi,
i've got 2 different domains both with the same problem.
both work fine as www.<domain>.net, but without the www i keep getting 403 forbidden status. any ideas?
i'm sure this is really simple but i've got no idea.
cheers
james
5 REPLIES 5
Ian1974
Moderator
Moderator
Hi James,
If you private message your domains to myself I will look into this as soon as possible.
Regards,
Ian.
Ian1974
Moderator
Moderator
Hi james,
Many thanks have just sent you a message.
You should be able to view you site without the www part within the next 4 hours.
Regards,
Ian
James
Master User
Ian1974: what change did you make here, out of interest? Just in case anyone else is having the same issue.
evilpop: is it ok now?
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
Thank you.
Ian1974
Moderator
Moderator
James,
Domain was using Url forwarding only on the WWW record and not the (@ none record).
If using the basic domain console to do this (see screenshot below) this only allows you to set forwarding on the
www record.
To resolve this customers need to use "Advanced manager" and set up the forwarding as per screenshot below.
Newdmc1.GIFHi
However customers can always use the dns enquiry form here if they wish for a member of the Dns team to carry out the request.
Sorry about quality of screen grab however if customers right click and save as they can view the full version.
But once in the domain console just carry out the following.
1. Type - Url or Frame.
(Url forwarding will change the address in the browser bar to the destination address and Frame will keep the original address typed in the browser bar).
2. Key - www to access website via http://www.yourdomain.com and @ to access via http://yourdomain.com.
3. Address - Address where you wish to direct the domain to (needs to be in the format of http://www.yourdomain.com).
Regards,
Ian
James
Master User
That's great, thanks Ian
Thank you.
