BethM
Administrator
Administrator
The way businesses make phone calls and connect to the internet is changing.
The UK telecoms industry is retiring the old Public Switched Telephone Network, commonly known as the PSTN, as traditional phone services move to digital technology.
For customers using the Openreach PSTN, the key date is 31 January 2027. If your business still relies on a traditional phone line, now is the time to understand what you use and what may need to change.
You may already have come across terms such as ADSL, FTTC, SOADSL, SOGEA and FTTP. But what do they mean, and how are they different?
What are ADSL and FTTC?
The difference between ADSL and FTTC is mainly about how the broadband connection reaches your premises.
ADSL, or Asymmetric Digital Subscriber Line, is an older type of broadband delivered over copper telephone lines.
FTTC, or Fibre to the Cabinet, brings fibre closer to your business. Fibre runs to the street cabinet, then copper carries the connection from the cabinet to your premises.
In simple terms:
  • ADSL: broadband reaches your premises over copper.
  • FTTC: fibre reaches the street cabinet, then copper completes the connection.
Some broadband services have traditionally been provided alongside a phone service that relies on the PSTN. As that network is retired, customers may need to move to a different service.
What are SOADSL and SOGEA?
SOADSL and SOGEA provide broadband without the traditional PSTN phone service.
SOADSL provides ADSL-based broadband without the associated traditional phone service.
SOGEA, which stands for Single Order Generic Ethernet Access, provides broadband using fibre to the street cabinet and copper for the final connection to your premises, but without requiring a traditional PSTN phone service.
SOGEA can be an option in locations where Full Fibre is not yet available. It is important to remember, however, that SOGEA is not the same as Full Fibre.
Which service is available to you will depend on the network at your premises, so it is worth speaking to your communications provider about your options.
What is FTTP?
FTTP, or Fibre to the Premises, is more commonly known as Full Fibre.
Instead of fibre stopping at the street cabinet, the fibre connection runs directly to your premises. This means your broadband does not rely on a copper connection for the final part of its journey.
Full Fibre can provide faster connections, greater reliability than older copper-based broadband and more capacity for connected devices.
What’s the easiest way to remember the difference?
Here is a simple summary:
  • ADSL: broadband delivered over copper to your premises.
  • FTTC: fibre to the street cabinet, then copper to your premises.
  • SOADSL: ADSL-based broadband without a traditional PSTN voice service.
  • SOGEA: fibre to the street cabinet and copper to your premises, without a traditional PSTN voice service.
  • FTTP: fibre runs directly to your premises.
Does every copper broadband service stop in January 2027?
No. The closure of the PSTN does not mean every copper broadband connection will automatically stop working on 31 January 2027.
The PSTN closure mainly relates to traditional voice services. However, a small number of broadband services still have a technical dependency on the old platform and could be affected when it closes.
Openreach has announced temporary safeguards intended to preserve eligible broadband services where technically possible. Some customers who have not migrated may also be moved to EVAc, a temporary emergency phone service.
These safeguards are not a long-term alternative to moving to a modern service, so businesses should not rely on them instead of making plans.
What else should businesses check?
Moving away from the PSTN may affect more than the phone on your desk.
Other equipment can also use a traditional telephone line, including:
  • alarms and security systems
  • CCTV
  • payment terminals
  • lift alarms
  • door-entry systems
If your business uses any of these, speak to the equipment provider to check whether it will continue to work with a digital service or needs to be upgraded or replaced.
What should you do next?
Start by checking which phone and broadband services your business currently uses. You should also identify any other equipment connected to your telephone line.
Your communications provider can explain which services are available at your premises, while your equipment providers can help you check whether alarms, payment terminals and other connected devices will remain compatible.
The most suitable option will not be the same for every business. It will depend on what is available in your area, the services you currently use and what your business needs from its connection.
With the Openreach PSTN due to close on 31 January 2027, planning ahead will give you more time to understand your options and make any necessary changes.
Do you know which technology currently connects your business? Have you started preparing for the move away from the PSTN? Please join the conversation below.
