3rd Party Routers
audrinabo
Member
I am trying to set up a Dray Tek 2832n router to use with my BT Business broadband but cannot get it it to connect to the line.  I have looked through this forum and used all the information I have found but cannot get itt to work.
Current settings are:
VPI 0
VCI 38
Encapsulation VC MUX
Protocol PPPoA
Modulation G.DMT
Authentication  CHAP
I have left the IP address assignment as dynamic and the username is the *****@hg70.btclick.com format along with the password I was given by BT.
Are there any other setting I need to add or change as I am running out of ideas?
Many Thanks
Matthew
14 REPLIES 14
kelper
Guru
My BTB hub has a static IP.  I think it took a day or two after connection. I have a second router connected to a LAN port on the BTB Hub which is not in bridge mode.  The second router has an IP address of 192.168.1.65.  Each router has its own wifi and whichever one I'm using, I have the same static IP as far as the internet is concerned.  The second one is using a VPN so I can have a 'presence' in USA.
audrinabo
Member
Hi PaulC1,
So do I set an IP address in the Draytek router of my chosing, or does it need to be the IP adresss in the BT hub that it uses to connect to the WAN?
Many Thanks
Matthew
PaulC1
Administrator
Administrator
Matthew,
Go into the BT Business hub via a webpage typing 192.168.1.254
Click on advanced settings and add your admin password, this is found near the barcode on the sticker at the back of the hub.
Then click on broadband, then routing and at the bottom of that list Bridging will be there. Click the slider and that puts your hub into bridge mode. You dont need to set any IP for the Business hub after that. You essentially turn the BT Business hub into a modem. All networking is done by your router thats been bridged. The Draytek will pick up an IP address from the internet as soon as it connects.
If you have trouble understanding this, or need a hand setting up. DM me and I can sort out some technical support to help you.
^PaulC1
audrinabo
Member
Perfect, all working.
Thank you PaulC1
Matthew
kelper
Guru
My Draytek Vigor 2820n will connect directly, replacing the BTB Smarthub.
The settings I used which differ from yours are as follows.
Protocol PPPoE
Modulation Multimode
PPP Authentication PAP or CHAP
It connects to the telephone wall socket ie copper ADSL
