BT Smart Hub 6 Comprehensive Manual
kschanna
Member
Hi
I need to have a comprehensive BT Smart Hub 6 manual.
I want to setup a customised Firewall and Routing for 5 Static IP's.
Thanks in advance
1 REPLY 1
Bobby
Super User
Hi kschanna
As far as I'm aware, there are no user guides for the functions that you've mentioned currently. You're best contacting the business technical team on 0800 800 154 for general assistance configuring that BT Business Hub, although by the sounds of what you're trying to do, it may be best to get in touch with the Enhanced IT Support guys on 0800 500 247 who specialise with internal setup. The latter number is a chargeable service.
Bobby
