Bridge/Routed Mode: Block of 5 IP's possible?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
I currently have a Hub2 in bridge/routed mode with a Meraki MX behind which is doing the PPPoE and firewalling. I have a single static IP. I have enquired about adding a block of 5 IPs and was told this is available for an extra cost. Fine.
I just wanted to check first that it is possible to use these 5 IPs if the Hub is in bridge/router mode? Specifically, that I can address services/ports to the IPs individually? For example, assume my public IPs are 11.22.33.44-49
11.22.33.44 > port 443 > internal server 10.10.10.1
11.22.33.45 > port 443 > internal server 10.10.10.2
11.22.33.46 > port 443 > internal server 10.10.10.3
Once again, the downstream firewall will effectively be handling the IP addresses and routing.
I'm asking because in this post the user runs into issues with a block of 5 IPs when using the Hub in normal mode. I plan to continue using my hub in bridge/routed mode, hence the question.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I can't answer as I only have one static IP. The Hub is either in bridge mode or router mode, bridge/routed makes no sense.
