Bt smart hub 3 disks
superman
Member
Hi,  I just got a Business smart hub 3 , FFTP and 500Meg , If  I run a 20M  cat5e from the hub what sort of free space wifi rate (no walls)should  I expect if  I connect a new black Square wifi disk to it ?
thx
1 REPLY 1
betty954bell
Member
With a 20m Cat5e backhaul, you can expect wireless speeds of 300–450 Mbps near the disk in an open space, as the Ethernet cable ensures the disk receives the full 500 Mbps capacity without signal loss. Since Cat5e supports up to 1 Gbps, your connection is fully optimized for your FTTP line.
