I was a long time customer on Home Broadband (Halo 150 i think) and then moved to BT Business Enhanced Fibre 76 (I think) because I need a static IP for my work.
It is not FTTP, but FTTC. I have a Business Smart Hub 2.
I still want to use the connection for streaming and some gaming, but expected that to be fine.
The connection went "live" on Friday last week but due to an Openreach issue didn't actually work until Monday (issue with jumpers in the cabinet).
Since Monday following an Openreach visit and fix at the cabinet, the connection has been "stable" I guess, but there have been huuuuge periods of high lag.
During these periods pinging google.com from the Ping screen in the router admin screens is giving over 1000ms. The download speed crashes to almost nothing, as does the upload. The periods can last from 5 minutes to 2 hours, regardless of what activity is happening on the network.
I set up PingInfoView to run a ping every 20 seconds and you can see here how it presents. Connection is running well then apropos of nothing, it starts lagging.
I also run PingPlotter, and here is what it looks like during the lagging period:
I'm being told the connection has a 10 day "settling in" period but this feels vague and wooly to me.
Does this look normal for the "bedding in" period? It's unusable during these times, which is a big problem for me.
Info screen is:
Serial number:+101221+2301002373
Firmware version:v0.25.00.01066-BT
Firmware updated:Fri Aug 11 09:48:44 2023
DSL uptime:0 days,09 Hours17 Mins29 Secs
Data rate:19.997 Mbps / 59.609 Mbps
Maximum data rate:20.194 Mbps / 61.861 Mbps
Line attenuation:4.5 / 10.8
Signal attenuation:4.4 / 12.5
Upstream error control:Off
Downstream error control:Off
Broadband username:[email protected]
Public Wi-fi:BT Wi-Fi - On
2.4 GHz wireless channel:Smart (Channel 1)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
MAC address:redacted
Software variant:-
Hii
You can ensure your firmware is up to date, and contact BT Business support to report the problem. They can perform line tests, evaluate network performance, and potentially suggest hardware adjustments or replacements. Monitoring your line quality and documenting the recurring lag instances with specific timestamps can aid in troubleshooting.
We can't see the images you posted until a Moderator approves them. I see from your post that FFTP mode is set to 'on', yet you say you have FTTC? Can you change that setting?
Another good site to check your speed and latency is Fast.com. After it gives your download speed, click on 'show more info' to get upload speed and latency. Post your results in text, not a screenshot.
