Please could someone view my sys log and see why my wifi keeps disconnecting?
kelper
Guru
I can use the internet for hours and then the wifi disconnects.  I can not reconnect with any PC or phone until I reboot.
When I try and connect my Android phone, it says, IP configuration failure so I think the DHCP has stopped working.
The ethernet keeps on working.
Not sure if I should attach the log here or not as it may disclose my IP address or some such risk.  But I could PM anyone willing to help.
1 REPLY 1
PaulC1
Administrator
Administrator
Hi kelper,
I’m sorry to see you are having wireless issues. Hopefully they are now fully resolved. If you are still having problems, PM me and I will try and answer all your questions. Whether they are having wireless issues or something else. I am here to help
^PaulC
