Re-purposing BT Home Hub 4.0 as an Access Point - Few Questions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I've noted down a good tutorial for doing this but it leaves a few unanswered questions:
Once it's setup correctly and working, can I use the ethernet ports on the Hub to access the parent network as if it was a switch?
Is it possible to clone the parent network SSID for seamless roaming throughout the house?
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello,
A few years ago I tried this and let's just say it was problematic after a few days - clients would drop off the network. I don't think any of the BT hubs are designed to be used in this way. You are better off getting a dedicated WiFi access point to do the job, or mesh type solution. If you need additional ethernet ports, buy an ethernet switch - they are cheap enough if you want something basic.
0
Kudos
