Removing inactive computers from the BT Business Hub 3
Jen1
Administrator
Administrator
Find out which BT Business Hub you've got.
The BT Business Hub 3 home page might display inactive users which no longer use your network.
You can manually remove them by following these steps:
  1. Open your web browser and type http://btbusinesshub.home in the address bar.
  2. Press Enter or your return key.
  3. Click the Settings tab.
  4. Enter your router admin password and select Ok.
  5. Click to select the Advanced Settings and then the Continue to Advanced Settings button.
  6. Select the Business Network tab.
  7. Click on the Refresh button to clear all inactive devices from the list.
All devices not currently using your network will be removed. Any devices currently using the network will reconnect automatically and shouldn't experience any interruption.
3 REPLIES 3
Noah5587
Member
Any update??
  1. Open your web browser and type http://btbusinesshub.home My HR KP in the address bar.
Any update??
Thanks, BT Community!!
ada8239523
Member
This is a great post. I like this topic. I found many interesting things from this site. Thanks for posting this again KanTime Medicare
