Find out which BT Business Hub you've got.
If you want to enable remote access to devices connected to your wi-fi network, you can open all ports, or selected ports on the BT Business Hub 3.
To set up basic Port Forwarding:
- From your web browser, open the Hub Manager at http://btbusinesshub.home
- Select Settings.
- When prompted, enter the admin password and click OK.
- Click Port Forwarding.
- From the Game or Application drop down list, select the rule you require.
- From the Device drop down list, select the device you want to access remotely.
- Click Add.
If the application you want to use doesn't appear in the list, you'll need to set up Advanced Port Forwarding:
- Select Settings.
- Click on Advanced Settings.
- Choose Port Forwarding and then Supported Applications.
- Select Add a New Game or Application.
- Enter Application name (this will describe the port you’re adding, and will also be used to name the port in the Game or Application drop down).
- Enter the Required Ports in the fields provided, click Add for the port required.
- Click Apply once all ports have been added.
- Go to Configuration.
- Select the newly created application from the Game or Application drop down list.
- If using defined IP, enter the appropriate IP in the box provided.
- Click Add.
