Site2site VPN BT Smart Hub options
amat1976
Member
Hi
I currently have BT business with Smarthub2. I am looking to have a site2site vpn which will be required from router not end client. It appears the smarthub is not capable if anyone has any reccomendations to replace the smarthub with a capable router or has an alternate method that has worked e.g keeping the smart hub and putting a vpn router behind it.
Any info would be great
many thanks
1 REPLY 1
itmika
Member
Hi Amat1976,
You can look into Draytek Vigor routers e.g. Vigor2860. Manufacturer prepared firmware to work perfectly on BT broadbands (ADSL and VDSL).
Thank you,
Jac
