Previously on my BT Business supplied Smart Hub supplied in 2020 I opened the Firewall and had full open access in/out to all my 5 IPs and devices behind those IPs.
I had no need to set up any Port Forwarding at all.
I have now renewed my BT Business contract and received the Smart Hub 2.
I can no longer get access to my devices behind my 5 fixed IPs.
I have step up the Smart Hub 2 correctly and BT level 2 and level 3 have have looked at my setup and ay it is correct.
They are sending me a new Smart Hub 2.
My concern is that there is something wrong with the Smart Hub 2 overall and a New one will probably have the same issue.
Strangely the devices behind each IP can browse the www fine 😮
But any attempt to reach the devices from external ,WAN, just fail.
Has anyone else had this experience?
I cannot use or set up Port Forwarding as each device uses the similar ports.
Port Forwarding on this new Smart Hub 2 that I have only seems to allow one use of a port across all 5 IPs, e.g:
The Smart Hub 2 will not allow me to assign port 5003 to more than 1 IP 😮 😞
Level 3 say that currently the software on the Smart Hub 2 does not does this (missing that required feature) and they have to send out a replacement older Hub version.
NEW Smart HUB 5 has fixed the IPs and FIREWALL issue ... however...
Now the Broadband speed is back down to my previous account speeds and no longer Down/UP 900/160 but 150-450/30.
Awaiting level 3 to talk up the management chain for throttling release?:
https://community.bt.com/t5/BT-Fibre-broadband/BT-Fibre-900-Upgrade-Smart-Hub-2-upload-throttling/td...
