A prime example of a useless system! Does it accept the old password? No!
Does it accept a new password as entered on the BT change your password (4 number pin required) screens? No!
Does it allow one to change-a-password? No!
A simple case of no joined-up-thinking! Well done BT. A system that cannot be accessed by any means must be secure! 🙄Outlook__2023-07-17 at 09.37.41.png
Why would it accept a new password if you can't remember the old one? You need a password reset, not a change password.
Hi jrhewitson
Are you able to log into business.bt.com? It will be the same password for there as it is for the outlook webpage.
To address your password-related issues, I recommend reaching out to the customer support or technical team of the system or service you are using. They will be able to assist you with the specific problems you are facing and provide guidance on how to change your password successfully. They have access to the necessary information and can help troubleshoot any issues you may be encountering.
