How to change "from" address in Outlook.!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
It doesn't work unless I use my default BT connect email address
Anybody have any solutions please?
Thank you in advance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Kingsongome
Sorry for the delayed reply, hope you are well.
Just to confirm are you looking to change this in an Outlook mail client? If so, I would recommend checking this article out, and if that is not helpful there is also a support link there for Microsoft.
You can also change your sender name in the settings of the email if you log in at portal.office365.com, but the "from" email address would still remain the same in that instance.
Regards
Ryan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
At the top of the page, select Settings. > View all Outlook settings.
In the Options pane, under Mail > Sync email.
Under Set default From address, choose an address from the drop-down list.
Select Save.
