On hold music on featureline phone systems
rebeccamillen
Member
We have 53 offices nationwide, with 3 different phone systems in place some are Cloud, some avaya and we have 14 offices on featureline phone systems, I am currently trying to find a provider to install on hold music, I am told that there is no way to add on hold music to the featureline phone systems, is this correct?
3 REPLIES 3
RyanJames
BT Employee
BT Employee
Hi Rebecca
As far as I am aware, you should be able to add in hold music via the team that deals with your system - if your phone system is maintained by us you would contact the relevant department on our end. For example, you mentioned Avaya - if we maintain your phone system and it is Avaya, you can contact the Avaya team on 0800 378 822. They would be best to sort this and give you advice in regards to this!
Hope you get this one all sorted!
Regards
Ryan
WillIcanDoit
Member
Habibi, you are able to hold the music no problem
Massimiliano
Member
Le suonerie telefon sono diventate un modo per esprimere la propria personalità attraverso il proprio telefono. Con e-suonerie.com, puoi trovare una vasta selezione di suonerie che si adattano al tuo stile unico.
