BT Cloud Phone Ongoing Issues
mcoleman
Member
We are a business and have around 9 BT Cloud Phones on our site.  Everything has been OK for 18 months and all of a sudden, the phones are failing - and at the same time.  Not all of them, but we currently have 4 of the phones not working.  Nothing has been changed in terms of broadband, router etc.
Issues are the phones going offline, the base stuck in a reboot process, and also not showing a line
I've spoken to support, but its difficult as each phone seems to have a different issue
Is there a way of arranging a BT Engineer to come in to look at the issue and try to resolve it ?
1 REPLY 1
aac74
Member
Might be a bad automatic firmware update?
Have you tried a factory reset of the phones?
https://business.bt.com/help/article/phone-line-and-services/cloud-voice-express/factory-reset-your-...
After resetting them and reconnecting them to the hub, you should also try to re-provision them by turning the affected handsets off and on again in the Cloud Voice Express Web Portal:
https://vel-btb.business.bt.com/ > manager all numbers > Click the wireless handsets > turn the affected handsets off and on again.
