BT CloudVoice - handset Phonebook connect error
AliHarris
Member
Our Yealink W73H handsets intermittently show "connect error" when trying to access the phonebook.
How can we resolve this please?
1 REPLY 1
AlanM1
Administrator
Administrator
The "connect error" typically occurs when W73H handsets fail to retrieve the remote phonebook from the base station (W70B). This can be caused by:
  • Provisioning issues
  • Certificate trust settings
  • Network instability or configuration mismatches
  • ✅ Recommended Actions
Check Certificate Settings
  • On the handset or via the web interface, disable “only accept trusted certificates” under security settings.
Re-Provision the Handset
  • Use the Cloud Voice Express portal or FusionPBX panel to re-provision the handset.
Factory Reset
  • Perform a factory reset using the “OK” button and default PIN (usually 0000 or 1379)
Network Stability
  • Ensure the handset is on a stable wired connection if possible, especially during provisioning.
Contact Support
  • If the issue persists, reach out to BT Cloud Voice Express support at 0800 011 3237 or via the BT Business Help Portal.
