BT One phone
YCSS
Member
We have had this system for over two years and its never worked correctly - as one previous complainant stated "its not fit for purpose".
We have complained many times and spent many wasted hours on the phone with no success and no solution. According to BT everything is "our fault".
At the moment we cant transfer and cant put people on hold - yes a state of the art system as it was described to us when it was sold to us!!
I have had calls from the BT Team and raised issue with them and they promised to get back to me but never have.
But the billing department works perfectly taking our payments without fail.
If anyone is thinking of contracting with BT I would advise them not to the systems and the support service is a disgrace.
2 REPLIES 2
jody998
Member
Hello,
Thanks for this info.
james598keen
Member
Hello,
It sounds like you’ve had a frustrating experience with BT’s system and support. Despite numerous complaints and time spent on calls, issues like transferring calls and holding are unresolved. Yet, the billing department efficiently processes payments. If you’re considering contracting with BT, be aware of potential system and support shortcomings. imedicarecard.com
Best Regards,
James Keen
