Hi there,
Is the BT Cloud voice VoIP supported on the BT quantum system. I have read that cloud voice does support some legacy systems. Is this able to be set up on BT Quantum?
Also, does the Quantum system support non-BT VoIP lines?
Regards,
Ryan
Hi rsmyth492
I would recommend talking to a Cloud Voice expert to discuss all the options - at the bottom of this page you can fill out your details and ask for a call back.
@rsmyth492 wrote:Hi there,
Regards,
Ryan
BT Cloud Voice may be supported on the BT Quantum system but it is best to confirm this with BT directly. While Cloud Voice supports some legacy systems, compatibility with specific models like quantum needs verification. Regarding non BT VoIP lines, the Quantum system might have limited or no support. It's designed to work seamlessly with BT's own services. For non BT lines, you might need to explore alternative integration options or consider a different phone system.
