The BT Quantum phone system is no longer supported by BT Business. Support ended on 30 September 2025, and we won't update this page if anything changes with the product.
If you're looking for a replacement system, check out all our cloud-based phone systems.
We've brought our BT Quantum diverting help together in one post. It covers diverting extension and group calls, ringing another phone when yours is busy, and diverting to external numbers.
You can divert calls meant for your extension, or for the group that normally answers incoming calls. Calls can be redirected to voicemail, another extension or an external number.
You can programme calls to ring on another phone when yours is busy by setting a divert on busy. The other way is a linear hunt group which you can find in our BT Quantum ring groups and hunt groups post.
Using a BT 8568 systemphone or a 5320/5330 IP phone:
Using a BT 8528 systemphone, Q DECT telephone, Q phone or a compatible standard telephone: Dial 733 followed by the extension or group number (180 to 190), followed by #.
Using a BT 8528 systemphone, Q DECT telephone, Q phone or a compatible standard telephone: dial 793 followed by the group number (180 to 190), followed by the extension or group number, followed by #.
By default, external diversion is restricted for all extensions. You can change this in system programming: as system administrator, follow the steps on pages 56 and 57 (Extension Diverts section) of the Administrator's Guide.
Be careful: it's possible for external divert to be misused.
Once you've programmed the system, the extension user can set up the divert using the steps above.
If you have ISDN lines, you can use BT's Digital Select Service Call Deflection to 'deflect' calls to an external number. Call Deflection is a network service and must be enabled by your network provider. Once enabled, the BT Quantum can be programmed to use it and the system's divert features then deflect calls to external numbers.
BT order details:
With PSTN lines, calls can only be diverted externally from the system using Select Services Call Divert, which is a network service.
If you've got a fault on your system, you can divert your calls yourself online.
You can find details in the BT Quantum User Guide.
