Cannot log on the cloud portal!
BCDental
Member
Hi
Logging onto the Cloud portal is becoming very problematic and frustrating.
I either get 'bad request' or 'this page isn't loading' errors.
I've tried opening the portal on different windows, different web browsers, incognito, cleared caches.
I've been trying to log on for over an hour trying different things. I cannot run a business when I cannot do the simplest task of logging onto the portal.
thanks
1 REPLY 1
daniel603maclis
Member
Hello,
You've already ruled out browser cache and browser-specific problems, this sounds more like a portal or server-side issue than something on your device. If other users are experiencing the same problem, it's likely a temporary outage or a backend authentication issue. I'd recommend checking the service status  and share the exact error messages and timestamps so they can investigate their logs.
