Cloud Voice Express app call history
rob-SMR
Power User
Using the app on an Android phone - is there a way to delete the "call history" - or "recents" as they seem to call it?
The list just grows and grows.
I can delete the history on the Yealink handset.
. . .  and it may just be me but the whole Cloud Voice Express thing is not very logical or intuitive - especially the app aspect. . . as an example, it seems I can't use my "contacts" in the diary/calendar app I use to make calls - but  have to create a separate list of contacts in the BT app.
7 REPLIES 7
SamG
Administrator
Administrator
Hi rob-SMR,
The Cloud Voice Express app will store the call history until it reaches its limit, at which point it'll automatically delete your history. No need to manually delete them!
Thanks,
^SamG
rob-SMR
Power User
Ah - so what is the limit number please?
- and my preference would be for the option to delete the history myself to keep things tidy.
rob-SMR
Power User
..  and while I'm here - when I make a call and then end it the number doesn't clear down from the dial pad? - should it?  - i.e. if I go to make another call with the dial pad the last number is still there.
MHA
Member
We too would like this feature. Who wants a cluttered up call list.  All it needs is a finger hold that allows a dustbin to discard rubbish calls.
rob-SMR
Power User
Perhaps someone might just read this . . . it can't be difficult to implement in the CVE app - every email app I've seen can do it.
Nobody has answered with the limit number . . . .
My phone is geting heavier with all the unwanted rubbish 😀😀
BethM
Administrator
Administrator
Hi both
I will take this feedback and pass it to the app development team.
^BethM
rob-SMR
Power User
Just to add - if you delete the app and reinstall the history is still there.
