I need help with adding answerphone system my email is [removed]
Hi haddon
What type of phones do you have?
Hi Haddon,
BT’s voicemail setup depends on which phone service you’re using, as there are a few different systems. The most common ones are:
1. Cloud Voice Express (CVE)
Voicemail is managed through the Cloud Voice Express portal under Features → Voicemail.
2. Cloud Voice (full system)
Voicemail is controlled through the Cloud Voice Manager portal in the user’s Call Routing → Voicemail settings.
If you can let me know whether you're on CVE, Cloud Voice, or another BT product, I can give you the exact steps for your setup.
— Unify Networks (Authorised Supplier for BT)
