Changing my website
frosty
Member
I have two websites that are hosted by BT, the newer one of the two is doing ok and is starting to get a few hits however i would like to change the other one to a different type of site, im happy enough with the hosting and webspace i have and am now well versed in how to create the site using easysite wizard its just that i now have a better idea for a site and want to utilise the package i all ready have without having to pay for anymore webspace, obviously i know i will have to buy another domain name, how do i go about changing my site?
1 ACCEPTED SOLUTION
Accepted Solutions
Tracey
Guru
Hi Frosty,
If you would like to change your website, and it was created by our EasySiteWizard tool, you need to login to your WebsiteOS(https://www.btdomainsaccount.com/login.aspx), choose Site Builders and select EasySite Wizard or EasySiteWizard Pro depending on what you package supports. In the case that your website was created by a 3rd party tool, you may use our File Manager tool in your WebsiteOS or FTP access in order to upload new files to your webspace.
Below are the FTP credentials
hostname:yourdomain.com
username: yourdomain.com
password: the password for yourdomain.com
You may use any FTP client, browser or command line. All files should be uploaded to the /public directory of your domain.
In order to obtain a new domain with us you can contact our Sales team on [email protected]
Hope this is of help to you.
Tracey
BT Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
View solution in original post
2 REPLIES 2
Tracey
Guru
Hi Frosty,
Tracey
BT Moderator
frosty
Member
Thanx Tracey il give that a go and see how i get on.
