Hi All,
I have browsed through the forums and from what I have read I'm not doing anything wrong, but I can't get Filezilla or dreamweaver to connect .
Here is a screen shot from Dreamweaver server settings can someone tell me where I'm going wrong?
I'm starting to get frustrated, been at this for a few days now off and on.
Hi,
The picture doesn't appear for me. Can you try uploading it again?
Kind regards
James
Faversham Designs
Lease your business web site for just £10 per month
Hi Buzz_Brown,
I have had a look at your domain name and FTP settings, and I can see no problem with them. I spoke to the helpdesk and they have tested your FTP details in Windows Explorer and in FileZilla which is working fine.
Dreamweaver is not a problem the helpdesk supports in using but if you go to this post by Sogo7, there are things you can try.
Regards
Markp
I feet like an idiot,
I found my problem, I had Advanced System Care 7 Pro running in the background.
So be warned all, switch of any thing that might impede your ftp program you are using.
Thanks all for your help ![]()
Pleased you solved it ![]()
James
Faversham Designs
