With all the different options, it can be hard for businesses to get the best broadband service for their needs. Let’s take a look at what’s available to BT Business customers to help you find the right fit for your business.
Fibre
If slow speeds are affecting your business, fibre broadband might be the solution. Fibre is much faster than standard broadband on a copper line, with speeds of up to 900Mbps.
Not only is fibre faster, it’s also more resilient and future-proof. Fibre is not affected by bad weather or distance from the network exchange, and by 2025, the UK’s copper network will be switched off.
You can check the availability of fibre in your area here: Business broadband and phone deals | BT Business.
If fibre isn’t available yet, take a look at the Openreach website to see when it’s due to arrive.
ISDN
If fibre isn’t available in your area, an Integrated Services Digital Network (ISDN) line could be the solution for your business.
ISDN services are high-performance voice and data lines, ideal for businesses with smart till systems that require reliable data transmission.
To find out more about the different options for ISDN, click here: ISDN lines | ISDN, ISDN2, and ISDN30 phone lines | BT Business.
Leased line
Do you need fast and reliable broadband to run your business and can’t afford to share your connection?
A leased line could be the answer to your broadband blues!
BTnet is our leased line for business – a private fibre line with 100% availability and maximum speeds of 10Gbps.
Want to know more about our BTnet products? Check out our previous blog on our leased lines for business: BTnet: An overview of a leased line for business.
Why not share your experience with these our broadband services? Get involved and share your thoughts and queries here.
^SamG
