Cannot connect to office routers. Traceroute fails on DSL but works on 4G failover.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I'm having issue connecting to BT IP addresses that I use for work. If I try with the DSL line connected traceroute fails, if I disconnect the DSL line and use 4G BT failover then it works correctly. Testing from other non-BT sites also works.
Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Martinbirch,
I have the same problem which you can see at
https://business.forums.bt.com/t5/Broadband/BT-blocks-block-of-static-IPs/td-p/88139.
The BT support says access to static IP is the owner problem and refuse to look into problem.
Moreover, I had some IPs which were blocked even by 4G failover.
Thank you,
Jac
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @martinbirch ,
I'm sorry to hear about the issues you're having. If you can please go to my profile and send a message I can get you in touch with our technical team to look into this with you.
Thanks,
^VickyK
