Replacing BT Smart Hub -> modem suggestions
kohramach
Member
Hi folks,
I'm trying to replace my BT smart hub as its coverage is pretty patchy in my house. I heard good things about the RT-AC86U but since it's a router I need a modem and looking around the combined price is making it look like I should just bite the bullet and go for the combo modem/router version for another 100 GBP.
My question is, is there a benefit to a separate modem/router setup or should I go for a combi, and if I buy this router what is the best modem that would be compatible with my ISP? I see the DrayTek Vigor mentioned a lot but all the amazon reviews are in German so don't know if I'm looking at the right thing...
1 REPLY 1
kelper
Guru
There's nothing wrong with the BT Smart Hub!  If the signal does not reach parts of your house, why not buy a range extender or a pair of Powerline plugs?  If you are determined to buy a new router, you can put the Smarthub into Bridge mode where it act as a modem only.  You can then connect a new router to the hub and the new Router will do the wifi business.  Which Smart Hum model do you have?
TP-Link make good Powerline plugs - look on Amazzon.  These use the house wiring to send wifi to anywher you plug in the second Powerline.
