Static IP for FTTP
packs
Member
Hi,
I've just been upgraded to FTTP and am currently on a dynamic IP address (I ordered a static one). The Openreach engineer thought that it should switch over to the static one once the old service is switched off.
I'm using a third party router (DrayTek) - do I need a specific login like I did the for ADSL static IP?
Thanks in advance,
Ian
1 REPLY 1
BethM
Administrator
Administrator
Hi packs
Yes, I would advise using your specific authentication username and password. You can get this by contacting the tech team. If you have any issues, please send over a private message.
^BethM
