Very slow Bt smart hub 2
Playboy124
Member
My wifi connection is horrible, it takes forever to download anything and i cant seem to do any work at all, things keep lagging and just stopping.
I have no idea how to fix it, help.
I have done the quiet line test on the phone and there was no noise at all. What does this mean?
8 REPLIES 8
kelper
Guru
Which hub do you have?  Which service do you have?  Can you connect your hub/router to the Master Socket so that all other devices are disconnected?  I don't work for BT but have sorted all my problems over decades as an internet user.
Playboy124
Member
@kelper
I have the Smart Hub 2 and i have already tried testing my internet with the master sockey directly. I even tried the test socket
However the stats are still the same
So i dont know what to do
kelper
Guru
But which service from BT do you have?  Have you tried connecting a computer to the hub directly with an ethernet cable?
Playboy124
Member
What do you mean by which service?
kelper
Guru
Do you have BT Infinity.  Is it FTTC or FTTP?  Or DSL?
macslever
Member
As Kelper mentions have you tried with ethernet cable directly. This will help you understand if its a Wi-Fi problem or an overall speed problem.
kelper
Guru
Why not say what you have tried?  Are asking for help or just musing?  😁
rachelgomez123
Power User
Try these steps
Use the BT broadband troubleshooter.
Make a call on your landline.
Restart your BT Hub.
Check the lights on your Hub.
Power cycle your Openreach modem (fibre customers).
Try your test socket – this is the main phone socket in your home
Regards,
Rachel Gomez
