I have just been advised that my ( bt connect business email address ) will no longer be supported when we move to business premises or upgrade to fibre I was passed through to so called technical support that gave very misleading information suggestion this was not going be the case!!.
This address we have used for 25 years plus.
Any advise would welcome.
Hi MDH,
So if you were to regrade your service, the @btconnect.com email address will be left unaffected and you will still be able to use it. If you were to move premises, then you would lose the @btconnect.com email address as the broadband service the email address is tied to is ceased off and a new provide ordered at the new premises.
I hope this makes it a little clearer
^PaulC1
Hello thank you for the info do I assume if one moves premises you auto loose your BT Connect emails this is a nightmare for any business in todays world!!
There must other options available.
MDH
@MDH wrote:Hello thank you for the info do I assume if one moves premises you auto loose your BT Connect emails this is a nightmare for any business in todays world!!
MDH
You’re doing a great job Man,Keep it up.
Just received an email from [email protected] <[email protected]> saying Still use your email addresses? Let us know so we don't deactivate your email addresses. Attachment is an htm file. Is this genuine or a scam? Thanks
I have the same issue can someone please reply to this post
My e-mails says:
Hello [email protected], |
Please make sure to state which of your email addresses you'd like to keep. |
