I changed from a BT domestic to a BT Business account. Since then caller display has never worked. When I was with BT domestic it worked perfectly. I use a BT 8600 cordless handset. I have the phone and nothing else plugged into the master socket, an OpenReach 5c. I have reported this five times and BT keeps closing the fault without ever checking with me. If I dial *#234# it tells me caller display is active. All I get for incoming calls is 'no number'.
Any suggestions? I have raised a complaint and that is crawling along but with no progress.
Solved! Go to Solution.
Hi Kelper,
I sent you a DM regarding this in November. Send me another DM and I can have a look at it for you no problem.
^PaulC1
Hi Kelper,
^PaulC1
All sorted thanks to PaulC1. Once the complaint was actually handed to OpenReach after eight months of reporting to BT. It was a broadband fault in the exchange.
