If I buy a Cisco ATA 191 or 192 via https://www.businessdirect.bt.com/
Will it come set up with Zero Touch Provisioning and work with Cloud Voice Express out of the box (following setup on the Cloud Voice portal)?
Solved! Go to Solution.
Hi aac74
No - you need to order an ATA through our support teams for it to be associated with your service correctly.
Hi aac74
